A
stillwellc
@hairbag1 wrote:
@stillwellc
click the little circle with the v in the top right side of your post to edit out the sensitive information. We're all just regular customers here...hopefully you do that quickly !!
@Dunkman , @softech
Unfortunately, replying to the member's message actually spreads the information further and makes it so that the OP cannot remove the information.  I have manually removed the phone number from each message in this thread.
hairbag1
@stillwellc
no need to include all your account info...what is the nature of your concern ? Did you reply yes to the sms sent to you ? Are you using an esim or hard sim for Public Mobile ? A bit more info please.
hairbag1
@stillwellc
@Dunkman , @softech
