11-06-2016 09:15 PM - edited 01-04-2022 06:06 PM
1) If i go to the states, and i have purchased the international calling add-on, will i be able to make calls while in the US? if not, how can i have roaming in the states if i need it
2)I need to change the credit card that autopay is coming from, do i cancel the autopay, the re-set it up?
Thanks
11-06-2016 09:42 PM
u don't have to remove the autopay u setup already, just login your account, payment,manage your card,replace this card, hit register after u fill up the form n done
11-06-2016 09:38 PM - edited 11-06-2016 10:00 PM
@zeja02 wrote:1) If i go to the states, and i have purchased the international calling add-on, will i be able to make calls while in the US? if not, how can i have roaming in the states if i need it
Thanks
You should just be able to go into your payments area and change the card your AutoPay comes from
11-06-2016 09:33 PM
11-06-2016 09:24 PM
if you have add on international call you should be able to make a call while you are in the state.
for autopay you should log in self serve website to update your credit card information
11-06-2016 09:22 PM
