90 day subscriptions.
bostrosky
Hello all.
I am assuming if I switch my 30 day subscription to a 90 day subscription that my legacy discounts will be tripled on 90 day subscription?
   Thx
@bostrosky  Yes you will keep old rewards and you will have 3x the rewards on 90 day I can confirm . I switch plans often and change mine I see the rewards 3x check it out
Dunkman
@bostrosky
Yes, your legacy discounts will be tripled.  However, your first payment for the 90 day plan would award one month legacy rewards.  Rewards are based on the previous payment cycle.  Afterwards, every 90 days, you will get 3x legacy rewards.
hi @bostrosky yes you are right.  Will be triple.  But on the 1st 90 days  payment , one 30 days discount because you just finished 30 days cycle. Then in the next 90 days, yiu will get thr triple
bostrosky
Thx for the speedy reply, much appreciated!
Chalupa_Batman
Hi @bostrosky that would be 100% correct. Legacy discounts are per 30 day renewals. Meaning 3x.
