09-01-2023
06:40 PM
09-02-2023
01:28 AM
computergeek541
when attempting to dial a Canadian phone number, get 8UV1 error message. Have reset my phone, have done an on/off of airplane mode, also a 'hard' reset on my iphone. My account is up to date, etc. what can i do to stop this happening?
09-02-2023 05:29 PM
Thanks for the update @Chalupa_Batman . I was wondering.
09-02-2023 05:21 PM
Looks like the problem was solved. A CS Agent was able to reset their network and things went back to normal.
Great to hear @ERose is back up and running properly.
09-02-2023 11:44 AM
Just sent request to CS Agent. Thanks for your help!
09-02-2023 11:31 AM
HI @ERose
still not fixed? did you submit a ticket with PM agent yet?
09-02-2023 11:30 AM
called with my husband's phone, also Public Mobile, and got thru with no problem.
09-01-2023 11:31 PM - edited 09-01-2023 11:31 PM
Hello @ERose , I found an older thread in the Community re: 8UV1 from late 2022:
Seems 8UV1 occurs during high call volume on the Telus/PM network. In this other example, it was only happening with calls made to toll-free 833 numbers. I didn't see a resolution listed within this older thread, but perhaps it resolved itself if it is a telephone network traffic error code. My suggestion if it continues, is to contact a Customer Support Agent for further assistance. I've included a link below:
Private Message to a CS_Agent:
Hope this helps.
09-01-2023 07:10 PM
Can you call the same number from another phone and what are the results?
09-01-2023 07:02 PM
I have ensured my call display number is on.
09-01-2023 06:53 PM
No, did not work after reboot. same message.
09-01-2023 06:49 PM
I have tried both ways and still get same error message.
09-01-2023 06:47 PM
Do you possibly have your call display off that others will see private caller when you call?
09-01-2023 06:44 PM
HI@ERose
Please try with and without the 1 in front of the 10 digits number, try both and it might work
09-01-2023 06:42 PM
Did you try going to settings, network settings, turn off automatic and choose Public Mobile. Then reboot. let us know if that works.
