02-11-2020 08:50 PM - edited 01-05-2022 09:28 AM
I bought the $25 plan plus the $8 add on for 200 minutes for us and canada. Wondering if i really need it. I call from Canada to the U.S. and get calls from the U.S. Do the incoming calls count in the 200 minutes?
02-12-2020 04:29 PM
Thank you!!
02-11-2020 09:27 PM
@sherryjr Your $25 plan allows you to receive calls from anywhere in the world without any additional charges. The 200 minutes will only be used when you make calls to the US from anywhere in Canada.
02-11-2020 09:21 PM - edited 02-11-2020 09:22 PM
@sherryjr No but the the outgoing, calls would. However, if you have a smartphone, and do all your calls to the US over WiFi. You can then us an app such as Google hangouts and Google dialer combined to make free calls to the US, if using an Android phone. OR the app TextNow. Over any phone
@sherryjr wrote:I bought the $25 plan plus the $8 add on for 200 minutes for us and canada. Wondering if i really need it. I call from Canada to the U.S. and get calls from the U.S. Do the incoming calls count in the 200 minutes?
02-11-2020 09:09 PM
@Anonymous wrote:@computergeek541 @Luddite maybe this could be moved up.
Moved to appropriate boards.
02-11-2020 08:53 PM - edited 02-11-2020 10:15 PM
No they don't.
Edit: Thanks NDesai.
