7b1 error
12-25-2023 02:40 PM
Toady is the 1st day of my plan change and I am getting an error message 7b1. I have unlimited minutes. I can receive calls and text but cannot call out. I have turned the phone off and back on. No change.
Service
12-25-2023 03:05 PM
Try resetting network connections and removing and reinserting SIM card (if you're using a physical SIM)
12-25-2023 03:00 PM
12-25-2023 02:45 PM
12-25-2023 02:45 PM
@justin83 Can you test the SIM card in another phone and test ? You can also get support to refresh your account might be all you need
send a private message To CS_Agents
12-25-2023 02:44 PM
Yes, today is the first day of my new plan. I have power cycled the phone but it did not work.
12-25-2023 02:42 PM
HI @justin83 you had a plan change? we saw some many issues after a plan change is made
But try to reboot the phone first, it heped my friend with similar problem after a plan change
if same, please submit a ticket with CS Agent here:
