03-31-2023 01:36 PM
Hello all. Receiving a 6UC2 code when calling out locally. Can you please advise?
03-31-2023 01:42 PM
Thank you. The 1 in front of number did work. Appreciate the quick reply
03-31-2023 01:38 PM
HI @Learnguitar
are you on $15 plan with only 100 outgoing minutes?
try restart the phone. And try calling different numbers
03-31-2023 01:37 PM
There has been some voice issue for some customers in the last couple days
Try this first, power off the phone for 5 mins and then power up and try again. Also, when making calls, make sure to include 1 in front of the 10 digits and see if it helps
If that does not work, please open a ticket with PM support for them to refresh your account, they will be able to resolve it
1. Please open ticket via Chatbot (need access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
