$60 / 30 days data issue
markliquid1
I am on the $60/30 days plan, which is no longer offered, but I purchased on October 1 (22 days ago).  I have used up the 8.5 GB, but my "Overview" tab shows 2.0 GB at 3G is still available.  I have used 0MB of the 2GB.  I believe this 2.0GB extra was part of a promo when I signed up.  How do I actually use it?  When I enter promo code "BONUSDATA", it says that I am not eligible for this promo.  A Walmart employee helped me sign up, I am not sure they took the time to enter the promo code during that process if that field was not populated automatically.  Anything I can do to access this data?
8 REPLIES 8
@will13am wrote:
@srlawren wrote:
@will13am wrote:
@markliquid1 , if all is going according to plan in your account, you would use up the included data first and then bonus data would be used next, followed by add-on data.  This would be automatic.
A rare miss from @will13am !  I guess nobody's perfect....
Oops I fell asleep at the keyboard.  I got the CAN/US deal mixed up with a different promo.  Smiley Embarassed
It happens
srlawren
@markliquid1 wrote:
Thanks for all the quick advice.
I will need to renew my plan early- how do I go about getting moderator help?
Click the ? in lower right side of screen. Type "renew plan" and follow prompts. You'll need to contact a moderator to renew early.
markliquid1
As mentioned earlier, that 2GB can only be used in the U.S.
As for BONUS DATA:  Sorry, but existing customers are ineligible for that promotion.  In addition, that promo code was not active yet on October 1.
Dunkman
@markliquid1
I think that the 2GB data is for US roaming only if it was the expired $60 plan.  You can't access that data unless you are in the USA.
https://productioncommunity.publicmobile.ca/t5/Announcements/Updated-Get-8-5-GB-at-3G-speed-2-GB-of-...
A couple of options:
1.  Renew your same plan earlier, but you will need to moderator help.
2. Buy data add on for 1 GB for $30.
will13am
