6 digit code
Becky8
I am trying to confirm my identity to finish setting up my account but i am not getting a text msg and it is not giving me the option to get it another way.
I think I may have put in the wrong imei number
Help i need my phone
2 REPLIES 2
ORNGNBLK
@Becky8   I have seen this happen if you are trying to setup using the web browser. You must use the PM App to fully complete the activation.
hope this helps
@Becky8
Are you trying to port in your phone number
the number could have sent to the sim card of your old provider if the port is not completed
And with port, it is better to provide the old provider account number instead of IMEI
There is a number to call to talk to live support and you can update them with the account number.  They can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But sometime this live support teams might say they can't help.  In such case, you will have to engage support team by Community messaging here:
