5g plans don't work?
22rabbit
Been using 4g public mobile a long time, switched to the new 5g plan.
The new 5g plan day kicked in and while my phone suggests I am connected to 4g, I actually get no service. No phone, no data.
Checked APN no change needed, rebooted,
@22rabbit wrote:
I found the problem, when I asked for it to switch to the 5g plan at end of billing cycle, it decided to cancel my subscription?
Wacky.
@22rabbit  I think the Autopay just failed
What current plan you see? if you see a 5G plan, click Pay now to resume services .  If you see your old plan, make a plan change now and make the payment, it should be good from there
@22rabbit  Very wacky indeed , sounds like you need to contact support
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
@22rabbit
Please login My Account using Incognito mode and confirm if PM renewed with the new plan successfully
what phone do you have?
what do you have for Preferred Network type or network mode?
Try to click Reset All Networks once
22rabbit
Wacky.
@22rabbit  Can you try SIM card in another phone and see if services work ? And try reset network settings .if issues persists please
add also any chance your out west seems to be some outages in bc
Outage   map in your area:
https://istheservicedowncanada.com/
