05-31-2023 04:09 PM
05-31-2023 06:02 PM
Just Not sure if the 5G Unlimited Data system would apply in this situation
05-31-2023 06:02 PM
Here's what I was told by a PM CSA
To answer your question, if your device has 5G capability but for some reason is not compatible with the correct 5G radio frequencies, you will still be able to connect your phone to 4G LTE speed.
05-31-2023 05:34 PM
Yes, I am getting 4g. I got a 5g 30-day plan.. 5 g on PM uses 5(850) band and my phone can use that from what I can see
05-31-2023 05:31 PM
@hTideGnow , I am not fully certain, and Any 5G phone needs to Support the Very Specific Radio Frequencies PM is using
That is very tricky
05-31-2023 05:29 PM
NP. The issue would be, Do you still have access to Data if Not on the 5G speeds, 4G LTE/ Advanced Speeds very least? If not, You better talk to a PM CSA and explore your options, as the Plan Cost is not cheap even under 90 day, if on the Higher Tier 5G Plan, and having to switch to a 4G LTE/ Advanced Speeds Plan would cost you even more if switching Immediately
05-31-2023 05:21 PM
https://www.publicmobile.ca/en/bc/get-help/articles/check-your-phones-compatibility
A PM CSA shared this link
Also, Check the GSMArena site and look at the 5G phones you own, that way you can have a Rough idea on if Compatibility is yes or no
05-31-2023 05:19 PM
A PM CSA sent me this link
05-31-2023 05:18 PM
No biggie. Thanks for your help
05-31-2023 05:17 PM
If confirmed, You could be Out of that Money as PM being Prepaid, Unless PM makes a one-time exception
05-31-2023 05:11 PM
https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/22437
This should be the PM CSA Profile
05-31-2023 05:08 PM
Mine is the SM-G986U
05-31-2023 05:05 PM
Is that compatible with PM?
05-31-2023 04:57 PM
You could be right. How do I contact them?
05-31-2023 04:56 PM
My thought, if Phone bought in US, Might Not be Compatible with the PM 5G LTE
If that is the Case, that might be the Culprit
Better Contact a PM CSA to confirm
05-31-2023 04:56 PM
thanks @makkahn28 they are all PM compatible 5G bands?
05-31-2023 04:54 PM
This what I see in the GSMArena site for that Phone Network Freqencies for 5G
5G bands | 1, 3, 5, 7, 8, 28, 40, 77, 78 SA/NSA/Sub6 - SM-G986B |
2, 5, 41, 66, 71, 260, 261 SA/NSA/Sub6/mmWave - SM-G986U |
05-31-2023 04:50 PM
This what I see in Wiki
Also, these from GSMArena for under Motorola Moto Edge+ 2023
5G bands | 1, 2, 3, 5, 7, 12, 14, 20, 25, 26, 28, 29, 30, 38, 41, 41, 48, 66, 70, 71, 77, 78 SA/NSA/Sub6/mmWave |
05-31-2023 04:47 PM
05-31-2023 04:45 PM
Yes I look on the coverage map and I am in the 5G 3500 zone. It is greyed out. Maybe Verizon greyed it out for a reason.
05-31-2023 04:40 PM
Hi @gbranscombe1963 but where you are? you sure you have 5G where you are? Your network mode should not be greyed out
05-31-2023 04:39 PM
So what does PM use a frequencies and I can check my phone to see if it does. Thanks
05-31-2023 04:38 PM
Hi @makkahn28
true. but US model of Samsung 5G would work here
and BTW, what are theb5G bands here for PM network? we have the information for 3G and 4G, not 5G
05-31-2023 04:38 PM
I have no idea.
05-31-2023 04:37 PM
Like I have stated my Network Mode says automatic and I can't change it because it is greyed out.
05-31-2023 04:36 PM
It is greyed out on my phone. Yes I have a 5g plan
05-31-2023 04:32 PM
PM needs to really lay out that info, as PM being a BYOD, Not all 5G Phones have the same 5G Spectrum Frequencies
05-31-2023 04:31 PM
@gbranscombe1963 @hTideGnow @esjliv , Here's the question to ask
The 5G Spectrum Frequency PM/ Telus is using, is it the same as what the US is using, or different?
05-31-2023 04:30 PM
hi @gbranscombe1963 did you chexk coverage map to see if where you are now has 5G ?
for network mode
05-31-2023 04:29 PM
05-31-2023 04:27 PM
No it has 5 G Samsung Galaxy S20+ 5g phone
