11-19-2019 02:34 PM - edited 01-05-2022 08:02 AM
I've purchased this add on. If my monthly minutes run out, will I still be abe to make and receive local calls using this add on?
11-19-2019 02:59 PM
@PAULRANG18 wrote:You will be able to make calls with this add on after your allotted plan minutes expire. The add on minutes will roll over to the next month until they are all used. You can then buy another add on.
Yes, you can control your plan to appear to be limitless if you took 2 add-ons and when one was used up......buy another.
But I caution.....don't load your account up with too much $$$ in the form of add-ons or $$$.
I am thinking 2 Canada Wide Add-ons and one Long Distance (just in case) which I doubt the latter will be used much.
11-19-2019 02:52 PM
2 more reasons why Public Mobile is such a great provider!
11-19-2019 02:51 PM
11-19-2019 02:44 PM - edited 11-19-2019 02:45 PM
@ecowen wrote:I've purchased this add on. If my monthly minutes run out, will I still be abe to make and receive local calls using this add on?
Buying the Canada Wide $5 add-on is a good idea. Just in case you use up your allotted minutes. The unused add-on minutes roll over month to month. IF you did use up your allotted OUTGOING minutes and you did NOT have the add-on, you would still recieve INCOMING calls.
11-19-2019 02:42 PM
Yes, it will remain in your account until you use up the 500 minutes.
11-19-2019 02:39 PM - edited 11-19-2019 02:41 PM
Yes all calling within Canada is allowed with this add-on including local, incoming and outgoing.
