Saturday
yesterday
Your phone also might be connecting to the strongest signal network in your area. You can check your network connection at different locations. If available and your phone is compatible, your phone sometimes will connect to the 5G network even though your plan is 3G or 4G.
Saturday
@erwindyck1 Go to phone’s settings, cellular data, select auto it 4G/LTE., you may need to reset your network settings
