4G phone with 5G plan
04-09-2024 11:03 AM
04-09-2024 11:06 AM - edited 04-09-2024 11:06 AM
Yes. Ignore the marketing for the purpose of this question, it's just about max speed. All plans can connect to all networks, with a compatible device. I have a 5G plan but often choose to connect to the 4G network.
04-09-2024 11:05 AM
HI @AnnaBrat
yes, it will work
the 5G plan is just about speed. You can use your 4G phone to access 4G network and have great speed like you have with a 5G phone.
04-09-2024 11:05 AM
you certainly can.
