11-19-2022 06:10 PM
11-19-2022 07:25 PM
I think saving $60 is the best choice for me. The extra 5 gigs sounds tempting but I really don't need the extra 5 gigs
11-19-2022 07:24 PM
I think most of us will be very happy with the $40 15 GB plan, maybe if they bumped it up to 25 GB then I'd reconsider! 😄
11-19-2022 06:51 PM
Pardon me, I meant chose to go for
11-19-2022 06:33 PM
@Glally if you worry about not enough data, then YES, $5 extra for 5GB is a great protection
But of course, that is $60 a year and if you can control the data usage, it is not bad to just save the money (Sorry, I am cheap 🙂 ).. or you can donate that amount for a good cause
11-19-2022 06:18 PM
@Glally wrote:Do you think 5 more gigs is worth it over the 15 gig plan?
Only you could really provide a fair answer to your self for that questions. If you'll use the extra 5GB, it's worth it, but if you never will, the opposite would be true.
11-19-2022 06:17 PM
11-19-2022 06:12 PM
@Glally wrote:Anyone tried the $45 20 gig plan?
Speed wise, this plan is identical to the other currently offered 4g plans. Is there anything specific that you'd like to know about this plan?
11-19-2022 06:11 PM
@Glally What do you mean by try?
