3g to 4g
savoimar
Hi, I paid for 4 g and my phone says still 3g   What do I need to do to make sure it's 4g.  The signal is terrible since that last month or so
10 REPLIES 10
savoimar
speed test 93.97 ping 60ms  I presume it's good
@savoimar
Which phone are you using? Where are you located?
You could try the SIM card in different working phone. That would help determine whether hardware issue versus Pm service problem.
You can test your speed via a few websites:
https://www.speedtest.net/
This will use up your data though.
@savoimar   which city and province you are at?
for speed test, check https://www.speedtest.net/ ,  They have apps as well
savoimar
Hi, it in town can be anyware the phone cut all the time  How to I do a speed test?  Thanks
@savoimar   did you do a speed test?  what speed you are getting?
And try to test it in different area as well,  it could simply be a weak spot at a particular location
savoimar
yes it shows I got 4g
savoimar
Hi thanks for info it's been 5 days
savoimar
Last week
Dunkman
@savoimar
When did you switch over to 4G plans?  It usually takes 2-3 days for the conversion to happen.
In your self service account, does your plan details show the 4G data?
A few basic troubleshooting advice:
Reboot phone
Network reset of phone.
Manually select LTE data on your phone (versus Auto).
Outdoorsman
@savoimar Hi it takes up to 48 hours for the 4g to kick in
