03-26-2026
05:44 PM
03-26-2026
06:01 PM
I have the same issue with a samsung s20 5g and still get this message. I'm wondering could it be due to an old sim card? I've been with public for years.
03-30-2026 02:20 PM
Thanks everyone! I borrowed a usable phone until I get a new one. I had success when PM sold pre-owned. I will try open box and Mobile Klinic.
03-26-2026 07:04 PM - edited 03-26-2026 07:07 PM
The way that Samsung labels their model is by years. Your Samsung S20 was introduced in 2020.
If you are looking at the Samsung S24 (2024) or S25 (2025) should be fine.
I would suggest you look at Mobile Klinik stores (Telus refurbished devices).
I purchase my devices from Openbox.ca online with stores in BC and Alta. They sell new, open box and refurbished devices.
03-26-2026 06:24 PM - edited 03-26-2026 06:30 PM
@Sunnygal wrote:Thanks! I am probably going to look at pre owned. Am I safe purchasing any 2024 or 2025 Samsung S series? Or what do I look for?
@Sunnygal yes, S21 and newer will work. But yes, it will be better (both with network and device OS updates) to get an S24 and above
For pre-owned, remember to buy it from trusted sources. I would avoid Marketplaces (like BestBuy/Walmart/ FB Marketplaces). While not all phones from there are bad, some got blacklisted phones and sometimes hard to get the money back
03-26-2026 06:22 PM - edited 03-26-2026 06:24 PM
Thanks! It said not compatible. I am probably going to look at pre owned. Am I safe purchasing any 2024 or 2025 Samsung S series? Or what do I look for?
03-26-2026 06:03 PM - edited 03-26-2026 06:04 PM
are you in Manitoba? PM will retire the 3G network in Manitoba starting April 2026. The rest of Canada will still has 3G network for a bit longer, probably another 18+ months
Although S20 5G has VoLTE itself, itis not a phone that will work with PM's VoLTE, you need at least an S21 series to use VoLTE on PM's LTE/5G network for voice calls once the 3G network is decommissioned.
FYI, to confirm if your phone can use VoLTE on PM's network, please use the IMEI checker here:
https://www.publicmobile.ca/en/get-help/articles/volte
