Sim Card not compatible
Finn16
I have an iphone X, when I signed up I paid for an esim card, the esim card came back not compatible, I spoke to Public Mobile and they suggested I order one of their Sim Cards which I did.  When I put the sim card in it comes up not compatible.  Has anyone else had this issue.
2 REPLIES 2
Finn16
Thank you so much for your help.
slusagm
iPhone X has no esim
and you need to ask PM to update the sim card number for you.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
