Tuesday
Would I be able to make calls in the US while I am there and would that include roaming?
Tuesday
Tuesday
@Chalupa_Batman Good point to mention and just to add to that @PGLarocque also check that your phone is on thenPM voLTE whitelist if it’s not calling can be a issue
VoLTE white list
Tuesday
just make sure you have a volte enabled cellphone for best talkability whilst in USA. You will not have any traditional "roaming fees" to worry about when you get back. Make sure to enable Data Roaming in settings...(actually, you can just leave roaming on as there will never be any roaming charges with PM as it's a pre-paid service)
Whilst in USA, best is to manually disable 5G and select 4G instead.
Tuesday
@PGLarocque wrote:Would I be able to make calls in the US while I am there and would that include roaming?
Hello @PGLarocque
I had this exact plan but $2 cheaper. I was able to use my unlimited talking minutes to call anywhere in the US and back home to Canada at no extra fee as it's included. I was also able to text friends and family here in the US and back home to Canada at no extra charge as it's included in this package. And finally, I had the 50GB of data that I was also able to use in the US while I was there as it's included in the package. Just know this, you MAY need to go into network settings and turn off automatic and click on T-Mobile as most have found that to be the best network to connect to while down there. I would also highly recommend to stay off of unsecure wifi locations in the US and just use the data. Hope this helps.
Tuesday - last edited Tuesday
@PGLarocque Yes absolutely that plan includes roaming calling to and from each country using in each country data talk and text no worries it’s true snow bird plan
