$35 canada-us plan
Viviancb
does the plan include calls and text in the US?
hairbag1
@Viviancb
if this is the plan you're asking about...then it does indeed, include talk / text and data while in Canada and USA. Make sure to read about VoLTE and make sure to enabled Roaming so you can use data while in USA.
@Viviancb  Some do but not all $35 plans offer calling and roaming in the U.S. so unless it says so under your plan details on payment page you can find out but for example right now the $35 35GB plan is just Canada wide on website right now . So check your account for the exact $35 plan you have
hairbag1
@Viviancb
yes it does. For use making calls in US, you must have a Volte enabled cellphone that is recognised by Public Mobile as not all are. Here's some reading with a device checker at the end of article..
https://www.publicmobile.ca/en/get-help/articles/volte
