$34 50GB CAN/US plan
EchoFive
Is there a way I can switch to this plan as an existing subriber? I have the canada only version from boxing day
Wellersbayview
Polite persistence sometimes works wonders. Don’t give-up at the first “no”. Good,luck.
@Wellersbayview wrote:
Is the system smart enough to know if you open a new account [different email, cc], activate an eSIM on the new-subscribers offer - then port an existing PM number to the new account? Porting my Telus # to PM was instant; <1 minute to complete.
A new account is still a new account.
Wellersbayview
@EchoFive  You can try and ask support sometimes they can help and other have confirmed getting the new activation only plans just by asking . If not and you only joined PM on Boxing Day and on points rewards could be worth while porting out to new provider and create a new PM account with new SIM card and buffet email and port your number back in from the new provider back in in the newly created PM account
send  a  private message   To CS_Agents
HALIMACS
@EchoFive
The only plans you can switch to are the ones displayed in your self-serve account.
Log in, go to Change Subscription, then review the plan options there.   If you find one you want, choose it and select to change on next renewal.
