11-10-2023 11:15 PM
Just switched from $35 20gig 4G, and switched to Point Rewards, which should give me almost 2 months free from next bill.
11-11-2023 12:30 PM
Only if you choose to switch to Point Rewards- I decided to grab the payout 🐶 $57 now, or $32 + $20 for next year on legacy Loyalty plan.. plus still get $1.75/month points on this plan, plus saving from previous plans.. it's 5G, and unlimited at low speed after 20g. I paid $55 for 50gig+ unlimited low speed last summer, and didn't really need all that data - just used it because it was there 🙃
11-11-2023 02:44 AM
Will I lose my old loyalty rewards if I pick this plan?
11-10-2023 11:53 PM
Didn't do autopay- and will likely be leaving country next year, and/or will switch providers.
Switching gave me 57 points, will cover fone bill for almost 2 months, right away. More cash for the holidaze 😎 Important for a pensioner..
11-10-2023 11:36 PM
@HJS_MTL1 wrote:I was only getting $4/month loyalty, soon to go to $5.. so potentially $60/year. Switching gives me almost $60 right away, then $1.75/month, $21/year. Just need to get in a few referrals..
Bird in the hand, etc. 🐶
How so? On the legacy reward system you get $2 for autopay each renewal. You are not getting that anymore. That $5 per renewal loyalty you won't be getting that on the points system. So you are giving up $7 x 12 = $84 a year for much less. I don't see how you come up with $60 of immediate rewards.
11-10-2023 11:30 PM
11-10-2023 11:23 PM
I did also switch to this plan from the next renewal, I am curious to find out what they have in store for the holiday season.
11-10-2023 11:21 PM
@HJS_MTL1 , good call on the plan selection. You indicated that you switched to the points reward system? If you were on the legacy reward system, I hope you did not make the reward system switch. The old reward system is more rewarding, no pun intended.
11-10-2023 11:17 PM - edited 11-10-2023 11:22 PM
Hi @HJS_MTL1
It is a nationwide plan to compete with Freedom's 5G 34$ plan.
