9 hours ago
Is this promotional plan 50 GB per month? It's not specified in the description of the plan. Thanks!
4 hours ago
It’s possible that the $34 60GB is targeted some customers with plans less than $34, to convince those existing customers to upgrade.
my point is this plan is way better than new customers plan, which is smart and good move for keeping existing customers and increase company profit at the same time.
6 hours ago
@EB0 wrote:This is the fist time in a long time that Public Mobile offers existing customers a better plan than new customers.
Existing customers $34 60GB 5G
This plan is not availiable to all existing customers. Public Mobile personalize plan offers for different customers. I cannot get this plan, and many others won't be able to either.
8 hours ago
new customers $35 60GB 4G
it looks a limited time offer that may expire tomorrow or by end of today.
if you are interested, you should go for it.
9 hours ago
@LSW17 that is a great offer. Totaling 60GB for $34. That is an insane amount of data for anyone!.
Most offers expires today, so if your going to get it, do it now as it might not be there in a few hours.
If you are currently with PM, you can use the Change on Renewal option to lock it in. No pro rated amounts.
Make sure you take a screenshot shot once you press save. You never know 😉
9 hours ago
HI @LSW17
the 10GB extra are "forever". The promotion date is just you need to get the plan before the date. After you subscribed to the plan, you will get 60GB altogether monthly unless you change plan yourself
