2FA Changes
kav2001c
I have said this before but I seriously HATE when Public makes random changes solely for the sake of change
As for the actual question can anyone explain to me WHY they decided to randomly change the two factor authentication?
It used to email a code. WHY is this no longer an option?
This eversafe loop is pretty mind numbing as well
It says I can't login without eversafe but then it tells me to get eversafe I need to login
Talk about chicken + egg
29 REPLIES 29
Meghann
try it when they have to text your account and your Phone is broken!!! that's a real treat... @CS_Agent  - i hope you hear me
maximum_gato
@kav2001d
Oh lucky you....yet another eversafe glitch. There's a process to go thru with customer support to get your original community account and username back. It's best explained by @esjliv .
kav2001d
I am cross posting this here
Previously I had all sorts of issues with Eversafe
Today I tried to login to verify renewal (90 day plans) and ... I entered the EXACT SAME email + password
It then prompts me to choose a NEW user name !!!
I type in old one and it cries old name already taken
So now I have a totally different account (somehow, I never registered again I used the OLD logins) and have no idea whether my accounts are linked or not
Plus I lost all my badges which is super annoying
kav2001c
*sighs*
It re-appeared again and no longer works again
Annoying...
This is correct solution as near as I can tell
You REQUIRE a PC, then REQUIRE authorize PC as trusted device
Weirdly its an ALL or NOTHING scenario
Once you TRUST the computer ALL 2FA is turned off
Otherwise you ALWAYS require the cell phone + computer to log in
My account is fixed but I repeat initial post this was not a good way to implement this
@BKNS27 , no, I haven’t had a computer in about 8 years! I use my iPad & it sends the 2FA to my Phone or email. I was just trying to get a workaround like TextNow!
Edit: Put eyeglasses on! 🤣
@LitlLdy
Did you try login to your account on your computer to get the 2FA code?
@BKNS27 wrote:
@LitlLdy @dust2dust
I haven’t tried on Eversafe ID but I tried when I login on new apps. Eg. WhatsApp awhile back.
@BKNS27 , ok. I can’t use it for 2FA, it wants $8.99 a week for that! Nope, not from me 🤣
@BKNS27- I just tried with my US service that uses vowifi and it worked. Seems we can't change that notification number to an existing Public number or use it in an additional account. We can change it to an external number or its own number.
@LitlLdy @dust2dust
maximum_gato
@kav2001c
I absolutely hate eversafe. That being said both of the following methods have worked for me with suspended accounts....one with email access and one without.
Log into eversafe that then sends the 2FA code via text message. In quick succession (but not too quick as digit boxes to enter numbers are slow) enter an incorrect code. I also check the trusted device box if displayed each time. Once you have entered 4 incorrect codes it will automatically give you the 3 options of text, voice or email.
The first time I tried this method I was unsuccessful then I realized my mistake!! I was waiting for a new code to be sent out and then entering an incorrect code. You want to enter 4 incorrect codes after just the initial 2FA code is texted to you.
The second method that worked which is more random with a little luck of the draw depends on whether you have access to a current or former telus phone that has been provisioned with wifi calling. ( You may also need telus home internet as well as that's what I have.) Put the Sim card of a suspended account in the "telus" device and log into eversafe. I was going to see if I could get the voice call either "live" or by accessing the voicemail. To my surprise I was able to recieve the initial SMS 2FA text.
In addition wifi calling on a suspended account will randomly work. I've tried testing to narrow down what works but it seems random with some phone numbers able to call the suspended account while others get the "US Roaming message" or the "Out of minutes" message when calling or they disconnect immediately. Same with calling out with the suspended account. Random?!!
If you are able to get a voice call keep in mind the voice speaks quickly and usually cuts out the first digit of the 2FA code so you need to listen to the second time when it repeats the 2FA code for you. Have a pen and paper ready or record the call.
Good Luck!
Weirdly darlicious stays logged in but her cat gets kicked out on the regular?!! Go figure?
Public Mobile is Grrrreat! 🐯🐈‍⬛😁
@BKNS27 wrote:
@dust2dust
I had issue with getting a verification code in the past but I realized I needed to update the TextNow app…no problem now.
I haven’t checked with the TextNow SIM.
@BKNS27 , I can’t get 2FA codes on TextNow app unless I pay!
@dust2dust
@dust2dust , no that wasn’t me. I have the TextNow app that I use for free calling but no U.S. SIM Card. I haven’t been to the U.S. in over 10 years!
@kav2001c  thanks for testing the workarounds, now, the magic lies with support, please message them.  Some get back the access  within hours.  Today is Sunday so I am not sure. But hopefully, you can give me good news in 2 hours
@LitlLdy   to change 2FA to another number, go to Profile page,  Manage EverSafe ID and you can change the phone number there.  The phone number with EverSafe ID can be different from your PM phone, so no worry if you want to change that
@kav2001c I also get promoted to send a code to my E-Mail when I click resend the code. My account is old, so that is not the issue. It seems your eversafeID is not set up correctly.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
But doesn't the app use the US side of things sort of like vowifi? Oh, weren't you the one with the US Textnow sim service?
Adding - @LitlLdy
@dust2dust , slow is wording it nicely! 🤣 I forget how to send it to a different #! But ya not TextNow without paying! I don’t have the SIM for it so not sure! I would have to be able to get to the U.S. to activate it unfortunately or I would have it! 😕
dust2dust
I can't stand these ssslllooowww systems they seem to like using but a nice thing I found if you "manage" multiple accounts is that you can send those 2fa texts to a different non-Public number like a voip app. Not Textnow as they want money for verification texts. I used a US number from Google Voice. Works great. I wonder if the sim-type US Textnow would work. Who was that.. @LitlLdy ? @BKNS27 ? One of those.
Yeah no that does not work either (truthfully I am a tad glad if I could override it I would be upset at them lol)
After enter the code wrong 5 times it just kicks out and asks re-enter email + password which gives me another 5 attempts
@kav2001c it is not random, just they adopted a new system just 2.5 weeks ago. Try the workarounds above, it helped many.  If not, message support and they can get it sorted out
Its random as I never added the 2fa they did that on their end (changed my account unilateraly)
Since I only login once or twice a year (usually when there is an issue) its not like I am online
dust2dust
I know you've been here forever but these are not random things. They did a system change last year which added the option for 2fa. Then recently with a whole other system where they now require 2fa and no option.
@softech- Did you mistakenly tag me? I bravo'd your post because I agreed with it after checking things again rather than writing a me too post.
@dust2dust that email choice will come, but complete your EverSafe setup first2
PM just changed to a new EverSafe login system and you need to complete the setup
Since you have not created an EverSafe id yet,  you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS.  (Sending the code to email would not be a choice until  EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps,  please open ticket with support and have them to help in this situation:
Private message CS agent at
Never even heard of eversafe before I attempted to complain to customer service
Its an old account so way before whatever random change they decided to make
(and for the record I NEVER added 2fa; they did that to me a few years ago randomly and now they added whatever else I just noticed today to remove the 2fa)
@kav2001c just tested and I have all the choices including email
was your EverSafe ID setup completed? you saw that choice before or never?  If never, your EverSafe ID setup was not completed
Nope this option has been REMOVED
It ONLY offers voice / text now which is why I am fuming
dust2dust
I think the automatic text should be stopped. Start the log in, it decides the username and password are correct, then give a choice of which method of verification the user would like to use. Or of course just have an option of not verifying at all anyway like the previous update had.
@kav2001c you can ask if to resend to email
at the 2FA screen, click Resend code and then Send email
