Thursday
- last edited
Thursday
DR_PM
Neither my husband or I can place or receive calls, but everything else works. Anyone else?
Thursday
I'm in New Brunswick same issue seems like this is a huge area of issue
Thursday
its down - make a service ticket
Thursday
Multiple people having similar issues - really wish PM makes some sort of announcement. Same issue for me (I'm in Newfoundland)
Thursday
Same problem here
Thursday
Thursday
I had this error this morning I fixed it by turning on Airplane mode and then waiting 30 seconds and turning it off
Thursday
only recent thing, sounds like a call goes out, but then static noise - dead air? is the network down, seems that its only Public Mobile which is down.
Thursday
Unable to dial out and have calls connect but can call within our family who have different plans. The number dials but does not ring.....
Thursday
Still not working
Thursday
I suddenly can't call anyone for no apparent reason and I need to call the non-emerge police for a follow up about last night. What am I paying public mobile for?!
Thursday
Exactly the same 😞
my device is 5g tjough
Thursday
its also here in Newfoundland, it was working fine until it went down? did submit a ticket any ETA on what's happening. did all the resets and reboots and etc still nothing 😔
Thursday
wasted so much time this morning, restarting my phone, trying to log into the app and still unable to make a phone call.
seems like I’m not the only one
Thursday
I am in ontario, i tried the reboot and I still cant get calls out. I will try again.
Thursday
Same issue with older non-5g device. Calls failing and nothing being received. Did all the reboot, reset, and APN. Something is up.
Thursday
I'm in Ontario. I can't make outgoing calls. I've tried a couple of numbers. When I try to connect a call, there is silence for a long moment, and then "call failed."
Thursday
Can’t make outgoing calls to non-public customers.
Can receive calls from none public customers
Thursday
How to raise a ticket?
Thursday
Following the guidance of live Chat with Public Mobile, I've restarted my device and tried selecting the network manually, but I still cannot make outgoing calls.
Thursday
ok just tested can get incoming but cannot make outgoing
Thursday
are you in Ontairo or Maritime?
please try Reset network settings after a device reboot. Please try calling different numbers (please note there is a problem with voicemail in Ontario)
if issue persists, open a ticket with PM Customer support.
Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account. Select Start a Chat to begin:
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
Thursday
It’s Thursday november 5th
is the service down? I cant make any calls
Thursday
same
Thursday
Called both the Alberta and Ontario numbers and same issue. Phone says "calling" with no dial tone and nothing happens
Thursday
rebooted, issue persists
Thursday
I appreciate the feedback but as this issue seems to be in other provinces and more of a broader network issue, I'm not going to wipe my network settings. I've called multiple numbers, and I've completed numerous reboots/restarts
Thursday
we get that on the first call, but if you try the same number again after that call drops/ends we get the 22P1 error. funnily we can call each other though, and we're both on public mobile, and we were able to call a friend on public mobile in Ontario too... but we hit this issue trying to call the MILs rogers home phone line.
Thursday
@MarkSquires wrote:Tried multiple numbers and same issue
can you try calling these 2 PM voicemail numbers in another pronvice?
587-580-4001 Alberta
778-580-4002 BC
Thursday
if you have a physical sim and you have another phone around, please try the sim card on another phone.
Also, do you have another phone you can test calling yourself to see if you can receive calls?
Thursday
