4 hours ago
3 hours ago
Sadly we are all restricted to higher priced plans available on our account and not plans for new activations. So be very careful when considering a higher priced plan because—- unless PM policy changes—-you will not be able to switch do a lower priced plan.
4 hours ago
That plon was only offered for select customers. What province are you in?
4 hours ago - last edited 4 hours ago
@Nadidi, you will have unlimited calls and texts within Canada and 20 GB of data at 4G speed, for $27 plus tax. You will need to respond fairly quickly as once it has expired you will not be able to get it back. Also note, if you do change to it on renewal you will likely NOT be able to get your old plan back which I'm sure is cheaper than this one.
