07-30-2017 11:01 AM - edited 01-04-2022 02:25 PM
I tried to purchase the above add on and it is no longer in the menu.
has it been removed?
Are there any pans to replace it?
Thanks
07-30-2017 11:38 AM
Hello DaveN,
Thank you for reaching out to us.
I am happy that your issue has been solved. 🙂
As the part of a Customer Service Experience Survey, I am inviting you to fill the form from this following link: https://telus.eu.qualtrics.com/jfe/form/SV_6tzYQ56VOqX4teZ.
Cheers
Abdoulaye
07-30-2017 11:22 AM
Yes it was and it worked,
Thanks for the help.
Dave
07-30-2017 11:16 AM
I am assuming this is for the US roaming ?
It should still be there, maybe try changing the browser, use Internet explorer , clear chache or use incognito mode in Chrome
