10-02-2019 08:14 AM - edited 01-05-2022 07:22 AM
I was referred by a friend and I activated my phone on Sept. 30. It is supposed to receive $20 referral credit but I only received $10.
In addition, my friend has not received any referral credit notice.
10-03-2019 04:58 AM
@edwinchan If you activated a $25+plan your friend will see a $1 reward in their account and you will receive a $10 credit in your account. Then within 72hrs you will both receive an additional $10 credit appear in your account.
10-02-2019 09:45 AM - edited 10-02-2019 09:47 AM
you should receive $10, your friend (refer u) receive $1. But with promotion period (25$ plan), you and your friend both receive $10. So you should not get $20. Your friend should get text message for refer successfully, and receive $1 not within the promotion period.
10-02-2019 09:27 AM
The timing for the bonus reward is different than the normal reward. Wait out the 72 hours and go from there. Patience is a virtue. ![]()
10-02-2019 09:04 AM
The referrer receive $10, the referree will get $10+$10 = $20.
@blessme4k wrote:You receive $10 and your friend will receive $10. That is the special promotion going on 🙂
10-02-2019 08:50 AM
10-02-2019 08:30 AM
@edwinchan also did you activate online and on a 25$ or more plan? Your friend should see the 1$ friend refferal reward right away in his reward section but the rest takes up to 72 hours
10-02-2019 08:21 AM - edited 10-02-2019 09:05 AM
The referral reward is for $1 and an extra one time credit for $10.
It can take 72 hours for the credit. If it has been more than 72 hours then submit a ticket by clicking on the question mark on the bottom right,
