2 step verification
Inclusive
 I am the admin responsible for payment of three different accounts and would like to remove all 2 step verification processes from accounts. It is next to impossible to retrieve account info when codes are needed from three different numbers quickly enough for submission to log in.
How can I access account with 2 step??????
Thanks
will13am
@Inclusive , you can use the trusted device option to stop 2FA selectively.
Inclusive
Thank you. This worked.
Inclusive
Thanks. This worked
@Inclusive
sorry, you cannot remove 2FA. More and more systems need it and cannot be removed
however, you can have it send to email instead
click Resend Code, Send email
if you want to be easy, you can go to those email mailboxes and setup forward rules and forward it to your own mailbox.
@Inclusive  Sorry you can’t . But you can change the number on the ever safe ID to send code too .
dust2dust
Click on resend code under the code entry and you should get an option to send to email.
