10-05-2018 07:36 PM - edited 01-05-2022 02:03 AM
When I activated my phone with PM, they asked me to choose a PIN number, I wrote xxxx.
After the process was completed, I received 2 sms, "Your new PIN number is yyyy" and the second one, "Your new PIN number is "xxxx".
How can I validate which one is the good one ?
Joining Public
10-05-2018 08:02 PM
Good to know.
Thanks,
10-05-2018 08:00 PM
@Sergio88 wrote:Ok thanks,
But what is the purpose of a PIN number ?
If you ever need to contact the moderator team, the way you identify the account you want them to work on is by providing the account number and account PIN. If you do anything on 611 like buy an add-on, they will ask for the account PIN to complete the transaction. I suggest you remember it somehow. It is not visible anywhere in the account and there is no reset function like for password. The only way to change it is to message the moderator team.
10-05-2018 07:40 PM
Ok thanks,
10-05-2018 07:37 PM
@Sergio88, the second SMS should contain the correct PIN code. Ignore the first SMS.
