03-04-2023 08:40 PM
I tried using the hotspot on my phone with 3 different devises. They all connect and show good signal. But no internet.
How do I correct this problem?
03-04-2023 09:11 PM
Tried it on my tablet too. 👍👍. Thanks softech!
03-04-2023 09:08 PM
@jim_h if hotspot works without the dun, forget it. Will take it as long as it works 🙂
03-04-2023 09:07 PM
Some of my other setting were not tha same as your APN settings posted. I changed them all to your example. And seems to be working! I still could not add in dun.
03-04-2023 08:57 PM - edited 03-04-2023 08:57 PM
@jim_h carrier allows just your phone not allows 🙂 We all can edit it
Try to see if you can create a new APN profile with all the settings there.
03-04-2023 08:53 PM
umidigi Bison
03-04-2023 08:52 PM
added ,dun on the end , the save. message comes up on the screen "Carrier does not allow adding APNs of type dun
03-04-2023 08:48 PM
@jim_h , what phone are you using for hotspot? There was a time that some devices required a tweak to the APN type setting. dun needed to be added. I had a couple of phones that needed this tweak to make hotspot work. Otherwise, Public Mobile didn't block hotspot use.
03-04-2023
08:46 PM
03-15-2023
03:19 PM
Luddite
@jim_h Try Reset All Network on the phone and see if it helps
If still does not work and if you are on Android , check and update the APN, especially check the APN type entry
APN: sp.mb.com
Proxy: and update
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
[ no dun today ......... Luddite]
03-04-2023 08:43 PM
