~1GB monthly data, very occasion voice and message - which plan?
04-15-2017 05:27 PM - edited 01-04-2022 01:40 PM
04-16-2017 01:28 PM - edited 04-16-2017 01:30 PM
The thing with data is we all tend to use what we have
Someone else mentioned above about the old 90 day 1GB plan (about 333MB per month)
Then there were the 600MB per month plans on other carrier
Then 1GB per month (3GB 90 days), 2GB (6GB 90 days) & 12GB (4GB 90 days)
If a person usually averages 1GB that is because they are (usually) limiting their use to stay within a set amount to avoid overages on old carrier
If offered more for a reasonable price it is a no-brainer to take and use
I also really like Publics 90 day options as they do provide great flexibility for that odd month where you need alot more than your average months
04-16-2017 01:14 PM
Even though @beejay request for a suggestion about 1gb data plan with few text n talk but as other said if by only paying few extra dollars user will be able to get double data sometimes it's good to be have extra if incase if required in future since it's s promo plan I would recommended to go by 6gb plan Pm offer LTE plan it's better to have 6gb if you only have to pay little bit more
04-16-2017 12:16 PM - edited 04-16-2017 01:32 PM
@MarieHelene_L wrote:
Yes according to the information we have I believe the 90-day plan with 3GB of data is a pretty good option. It's not 3GB per month, it's 3GB for the entire 90-day period which averages to approximately 1GB per month, exactly what @beejay requested 🙂
The suggestion is that it's far better value to pay a few dollars more per month and double the data to 6 gigs over 90 days.
04-16-2017 10:21 AM - edited 04-16-2017 10:49 AM
*Please do not post private info such as: phone number, account number, PIN etc... This is a public forum!*
04-16-2017 09:48 AM
@mimmo wrote:if going the for data only plan, there were other providers offering $15/month for a couple gigs /month not sure if those plans are still around
Yeah, the Fido data plan is still available. However, you need to be a existing customer with a talk plan to qualify.
04-16-2017 09:29 AM
04-16-2017 08:13 AM
Just to make things more complicated for you @beejay, you could select a 6GB data-only plan for 90 days at $84 then sign up for a service such as Fongo to get a phone number and text through your data plan...it might be more economical if you are not a heavy phone user and rely more on data.
04-16-2017 08:10 AM
I would have to agree with @kav2001c, simply due to the value of the plans. I'm on an older (no longer available) 1GB for 90 days plan and even though I don't use that much data, if I decided to upgrade I would likely go for the 6GB plan ($111 for 90 days vs. 120 for 90 days and double the data...).
But of course, this why Public Mobile is awesome, there's a plan for just about everyone!
04-15-2017 11:39 PM - edited 04-15-2017 11:39 PM
@paulie & @MarieHelene_L & @cricketfan really???
He averages 1GB per month so you suggest the 3GB plan?
@beejay take the 6GB option; cost difference is only $3 per month more and you have alot more room to breathe
04-15-2017 08:49 PM
Yeah, the 90 day option is a no brainer. The cost per month is lower and the data carries over for the entire duration, making for great flexibility.
04-15-2017 07:13 PM
04-15-2017 06:50 PM - edited 04-15-2017 06:51 PM
best to go with the 90 plan mentioned above.
Also be sure to add autopay to receive some discounting...
http://productioncommunity.publicmobile.ca/t5/Rewards/AutoPay-Reward/m-p/404#M3
04-15-2017 05:35 PM - edited 04-15-2017 06:46 PM
Hey @beejay
Thanks for choosing us! We're glad to welcome you into the Public Mobile family 🙂
Here are the 2 suggestions I would have for you,
- A 30-day plan that includes unlimited province wide calls, unlimited international text and 1GB of data for 42$
- A 90-day plan that includes unlimited province wide calls, unlimited international text and 3GB of data for 111$
You can also consult the plan creator available on our website to see for yourself!
https://publicmobile.ca/en/on/plans
Thanks 🙂
Marie
