10-06-2022 04:16 PM
Hi, My name is Sébastien. In am unable to subscribe to the 15gb 4g plan. Is there a reason why. When I click on the plan at the website it takes me to the details of the 10gb 4g plan instead.
10-06-2022 04:26 PM - edited 10-06-2022 04:27 PM
@Metal1967 There is a $60/10 GB 4G plan on the plans website? Or is it not available in self serve?
edit: nmd re-read but both plans appear on the website..
10-06-2022 04:25 PM
That's odd. When I click on the $65 15gb plan to change, it goes to the next page with all the same info. Maybe try using private mode. Did you click the yellow arrow down to make the $65 plan be highlighted?
10-06-2022 04:23 PM
Probably not
10-06-2022 04:23 PM - edited 10-06-2022 04:24 PM
@sebasboucher Are you trying to activate a new account or are already a customer?
If the latter, then clear browser cookies/cache and use incognito mode to login into your account and select Plans/Add-on from the left side of page and then click Change My Plan and then you need to click the arrow on the right side of page if on desktop or bottom of page if on mobile device.
If you're a new customer wanting to activate then you need a PM SIM and CC and proceed to follow the activation instructions via the this link: https://activate.publicmobile.ca/
10-06-2022 04:23 PM
10-06-2022 04:22 PM
