12-02-2016 12:18 AM - edited 01-05-2022 01:08 AM
12-04-2016 02:17 PM
12-03-2016 09:08 AM
12-02-2016 12:18 PM
12-02-2016 11:28 AM
You could try this while you wait:
Meanwhile, an application like that from fongo.com might be useful. It provides a free number and calling across Canada from wherever you are connected to wifi, or cellular data. Incoming SMS is also free.
If calling your old number goes to voicemail you can, at least, retrieve messages.
12-02-2016 12:35 AM
12-02-2016 12:25 AM - edited 12-02-2016 12:26 AM
Relax, I'm also 12 days in, my msg is also unread atm. But msging multiple times does not help the situation, it just means the mods will have to look at your msgs multiple times instead of helping someone who in just as much of a hurry as you. If I had to hazard a guess, they're halfway through the 19th and they're continuing as fast as possible. I know this situation sucks but it is what it is, and spamming the system won't help you, me or anyone else in a hurry.
