10$ credit..plan change from 35 to 30 plan
sweetcute123
Hi
I am currently enrolled in 10$ promotion for 6 months in a 35$ plan. I was wondering if I change my current plan to 30$; will I still be able to receive the 10$ credit for the remaining duration of 6 months promo?
Changing plan shouldn't affect my credit if it is still 30$ plan?
Pizzaeh
@sweetcute123 wrote:
Hi
Correct, as long as your plan is $30 or more, you will continue to receive the $10 credit, so you're good.
Alex888
That should be fine, I think you need to have a $30 plan minimum to qualify for the $10/6month credit so as long as you stay on a plan above that it's fine.
Just a reminder, if you choose to change plans immediately you forfeit the remained of your current plan, you can choose for it to change automatically on your next renewal date without losing anything.
Lieux
No problem you will keep your 10$ credit per month Smiley Happy
popping
Hi
Yes.  Switching to a $30 plan is still meet the $10/m requirement.  You will continue to get the $10/30days.
PM is prepaid service.  Make sure to schedule your plan change to your next renewal day.  Otherwise, you will not get refund of the unused portion of of your current cycle.
NDesai
@sweetcute123 Yes, you will continue to get the $10 credit because the $30 plans also qualifies.
