$10 Referral Not Showing in MyRewards
mayank646
Hi,
I have recently joined Public and have used one of my friend's referral code. But $10 bonus is not showing in my rewards section ?
Thanks
10 REPLIES 10
gpixel
@pame that's great! welcome to pm!
pame
I didn't receive the $10 credit after the required 72 hours and I contacted the Moderator team and they were able to fix it quickly.
@mayank646 wrote:
Does that mean it will be credited in the next billing cycle ?
$10 will be deducted from your 2nd month's bill. As well as $2 if you are on autopay. With an additional $2 from your 1st month's bill if you signed up for autopay.
Welcome!
@mayank646 No, you will get it in this cycle. Just wait for 3 days after your registration here. You will see it the reward after that.
As others have mentioned, it will take up to 72 hours. If you haven't used that $10 balance for anything when the next renewal comes around, that $10 will reduce the amount that needs to be paid for your plan.
mayank646
Triguy
It can take up to 72 hours to appear in your account.
@mayank646 wrote:
Hi,
Thanks
The $10 credit isn't considered a reward by Public Mobile, and as such, will not appear in the rewards section. It will be desposited directly into your account balance.
gblackma
Welcome to PM @mayank646 the $10 one time credit is usually credited to your self service account within 72 hours.  Stay safe.
JoyLuck
@mayank646 wrote:
Hi,
Thanks
It takes up to 72 hours for the reward credit to show up.
