$10 Promo Credit
06-29-2024
12:44 PM
06-29-2024
01:42 PM
Dunkman
I did not receive my $10 credit for being referred by an existing Public customer. The promo code I was given was xxxxxx. It did not work when I entered it. I was referred by xxxxxx.
Joining Public
06-29-2024 04:04 PM
@BKNS27 wrote:Double check the referral code to see if there a mixup with S/5, I/1 or O/0.
If the code doesn’t have any of these alpha/numeric numbers then it will take about 72 hours for the $10 credit to be added into your account to apply on your next month bill.
I would say that it's unlikely the code was entered incorrectly. If someone were to mistakenly enter an O instead of a 0, that would likely make the referral code invalid. When that happens, the activation system will return an error messgae.
06-29-2024 02:21 PM
06-29-2024 12:57 PM - edited 06-29-2024 01:01 PM
Hi @Larry_Orr, this is a public forum so you'll want to remove personal info like names etc by clicking on the very small circle with a v in the top right corner of your post.
It might take up to 72 hours for it to show up in your account. In case it has been more than 72hrs, is it possible that the O (letter) is not supposed to be a 0 (number)?
You will need to open a ticket through the Chatbot and as the CS agent if your code was not applied:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
