09-15-2017 02:28 PM - edited 01-04-2022 02:38 PM
Hi,
Now that iPhone 8 and iPhone X have been revealed, I am wondering if it will be compatible in Public Mobile service. I haven't decided as to which phone I will go for, but is it simply to change the phone? Like just put the SIM card in a new phone and ready to use?
Please advise and thank you so much!
Phones
11-04-2017 02:58 PM
Thanks for the confirmation!
09-30-2017 12:53 PM
yes, its normal
09-29-2017 04:36 PM
@yougenius wrote:I have an 8 Plus and everything seems to connect ok. I noticed that when making a phone call it switches to 3G, is that normal?
That is normal, because Public Mobile does not have VoLTE (Voice over LTE), so it switches to 3G to make the call.
09-29-2017 04:17 PM
09-23-2017 09:57 PM
Hope you will like your Iphone. Waiting for Next Gen Pixel Launch.
09-22-2017 09:26 PM
I got my factory unlocked iPhone 8 today, and as predicted it has no issue on PM.
09-16-2017 08:59 AM
If you buy it directly from Apple without a service plan activation it will be unlocked.
09-15-2017 08:06 PM
Just make sure it's an unlocked phone (locked to Telus/Koodo may still be ok, I'm not very familiar with iPhone's proprietary locking mechanism).
09-15-2017 07:50 PM
There won't be any issue, as the bands the iPhone 8/X have are still supported by all the major Canadian carriers.
They do also support Freedom's LTE Band 66.
I ordered an iPhone 8. I'll post a quick "yes it works" next Friday!
09-15-2017 03:06 PM
@HLONDONH wrote:Oh perfect! Thank you so much @Wonder_why!! I really appreciate your fast response 🙂 All I have to do is to put my current SIM card in a new phone right?
Correct 🙂
But if the sim size is different: smaller then what your current phone uses, you can punch it out to get nano sim. If not, you can just buy new one online or at Walmart/wow mobile and change the sim number in your self-serve account.
09-15-2017 02:39 PM
09-15-2017 02:31 PM
@HLONDONH Yup compatible to PM all IPhone 8, 8 Plus and X
