It does seem to be a bit slower than Telus (my previous carier) but for the value we get with PM - no complaints at all!
I just switched a phone from Koodo prepaid to PM, and we can see a difference on speedtest...
Effect in real life: should be next to nil...
On the other hand, a speed test on Koodo prepaid is expensive
I finally managed to do some testing with a Bell SIM and PM SIM during off-peak hours under excellent signal conditions (SINR 25+ dB) with the tower unloaded.
AMBR value is not the issue. It is set to 1 Gbps downlink for both Bell and PM subscribers. However, DL speeds are consistenly lower on PM.
I used the same phone, 5 speedtests with Bell using 3 different servers, followed by 4 speedtests with PM, using the same 3 servers. eNodeB (tower) usage was very close to zero at all times. I verified this but cannot share the screenshot on a public forum.
Here are the AMBR confirmations:
Here are the speed test results:
This was tested on a site with B2 + B4 CA, which the phone supports and was verified active for all tests. I don't have a Telus SIM to compare, so I can't be sure if this is strictly a PM issue, or all Telus subscribers. What is clear from this test is that there is definitely a limitation for PM users at the very least (possibly all Telus users). Either way, the issue is with Telus, and not Bell.
@sheytoon Great information, thanks! Out of curiosity, where were these speed tests performed?
In the Toronto area near a site that I like to use for testing.
If I remember correctly, Bell is the only carrier right now that had three carrier aggregation (Max speed 335 Mbps). Rogers and Telus are still using two carrier aggregation (Max speed 225 Mbps).
This is what I got at pearson airport using Public Mobile
http://www.speedtest.net/my-result/a/2464912397
It says Telus, but I am using Public Mobile.
If they throttles, then not sure what speed they throttled at...
This definitely looks like 4G speed VS 4G+ speed...
Did Bell get LTE-Advance already, but not telus?
