Data not accessible
Bukas
I bought a new public mobile sim last month and I did a 15$ plan which was supposed to come with a 250mb data. However this data has been unaccessible. I use wifi at home but every time I step, I tried to switched to the 250mb data, it never worked. I have never had internet access to the 250mb data on my freedom mobile number and my subscription is to be renewed in 6 days time
@Bukas wrote:
Thank you.  Yes, thereathere is a 250mb block of data unused
Did you try the APN settings provided earlier? And then turning on cell data?
Your make/model got a little lost in translation... Huawei something -U02. What was the something?
Bukas
Luddite
@Bukas Do you have autopay set up?
  • yes >> login to your account and see if there is a 250 meg block of data showing. If missing suggests you used it up.
  • no >> autopay is required to get that data bonus
@Bukas try the APN settings below.
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Save, enable data and try sending an mms message and surfing the internet. Stay safe.
Bukas
My phone model is Huwai **bleep**-U02. Any idea how I can resolve the issue on this phone?
gblackma
@Bukas what's the make and model of your phone?  If you could never access it. It sounds like a APN settings problem.  Enable data and try sending an mms message. If you can, your APN settings are correct.  Of you cant, in general, 20200506_104406.jpg
Stay safe.
