Wondering if I can get a refund
Niceguy
Bout a data plan for the wrong country wondering if there is a refund process?
2 REPLIES 2
HALIMACS
@Niceguy
You can ask customer support to credit back the purchase, or they can apply the purchase credit to the desired add-on instead.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
fixin1
@Niceguy - CS_Agent can credit you the amount and so then you will get a discount of your next bill with public mobile:
Submit a ticket via Chatbot:
⚠️Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article!   ⚠️
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
