07-28-2020 12:27 PM - edited 01-05-2022 12:35 PM
I unfortunate locked myself out of my phone but fortunately got back in. Everything seems to be working but I cannot make calls out or receive calls. Texting is working fine.
Can anyone help?
07-28-2020 02:16 PM
I really appreciate your help. It is working again, thanks to your suggestion
07-28-2020 01:47 PM
@maudiemay great that we could assist you. I think that the solution should go to @totalUser . Since the suggestion to switch to 3g was that monikers. Stay safe.
07-28-2020 01:42 PM
You are an absolute star. Switching to 3G worked. I can now phone out.
I will be saving that info in case I should need it again.
Now I can resume my life. Can't believe how important my phone has become to me.
Thank you for your help.
07-28-2020 01:40 PM
@maudiemay Are you on the $10 plan?
07-28-2020 01:37 PM
If you go to settings then network, then movie network, then advanced, then preferred networks you sound have options to switch between GSM, 3g and LTE possibly even more combinations, depending on your phone
07-28-2020 01:34 PM
Dnd wouldn't be the problem, it would never prevent you from making a call
07-28-2020 01:33 PM
Thank you. You have really given me great info. I'm in the process of following your instructions now and will reply when complete.
07-28-2020 01:30 PM
@maudiemay to switch to 3g
If this fails try a network reset and restart your phone if it doesn't automatically do.
Stay safe.
07-28-2020 01:26 PM
I can't find do not disturb anywhere in my phone
07-28-2020 01:25 PM
I don't know where to find 3G or if I am on that or not
07-28-2020 01:24 PM
No, wasn't playing with any of those.
07-28-2020 01:24 PM
Yes, I've tried all those in fact several times
07-28-2020 01:22 PM
Moto E4
07-28-2020 12:47 PM
@maudiemay Did you try restarting phone, using fly mode or lost/stolen feature in self-service? Sometimes, turn off the phone and leaving it for a few mins and then turn on helps.
07-28-2020 12:41 PM - edited 07-28-2020 12:42 PM
Were you by chance playing with Call Barring or Fixed Number Dialing in the phone app ? If so you may have inadvertently set a PIN2 lock code on your SIM. This will allow calls only to a few specific numbers you setup (or none). If you did, and you dont know what PIN2 code you used, you might need to contact Public Mobile moderators to get the PUK (Pin Unlock Disable) code for your SIM to disable it again...
07-28-2020 12:37 PM - edited 07-28-2020 12:40 PM
@maudiemay check to see if "do not disturb" is enabled and disable it. try resetting your network settings and restart
07-28-2020 12:31 PM - edited 07-28-2020 12:32 PM
Try switching to 3g only and test it
Sounds like you are on lte only
If it works on 3g switch to auto then restart
07-28-2020 12:30 PM
@maudiemay hello what plan are you on? what is the make and model of your phone?
07-28-2020 12:30 PM
@maudiemay what's the make and model of your phone? Thanks. Welcome to PM. Stay safe.
