Reward points
cloudalabama
how do you earn points on this forum?
Shaej21
I was also wondering the same thing. Thanks for the suggestions!
@Ddick
Yes that is correct. It is based on how many Bravos (Likes) and PM staff will decide on how many points you will receive.
Ddick
From what I understand, you answer questions with helpful solutions, then someone decides on how many points (rewards) you get.
@cloudalabama
- Try to help other members on their service, porting, login or any others issues/problems.
- Recommendations are based on your and other member experiences.
- The number of Bravos you receive based on your recommendations.
- The number of Solved Solutions.
- Try to have fun helping others.
@cloudalabama  By helping to answer questions and participate get and give bravos and accepted solutions
