Is 4g better than 5g?
11-26-2023 01:36 AM
any one feel like 4g is faster 5g
11-28-2023 12:42 PM
It depends in your service area. If your are in an area of good 5G coverage, you will definitely get much faster speeds with 5G. If you are in more rural areas, where 5G coverage may not be as good, then it is possible that 4G will give you better speeds. In some remote areas, you may even lack 5G/4G coverage, then you may only be able to get 3G coverage. Try and test speeds at different areas and you will see the difference.
11-26-2023 10:35 PM
I definitely find 5G faster when watching videos or doing video calls. But for surfing the web, 4G is plenty good.
11-26-2023 11:47 AM
HI @Momomomomo
5G is better, but wast more money. And many really don't need the extra high speed , 100Mbps on 4G is more than enough
