10-13-2025 04:56 PM - edited 10-13-2025 05:36 PM
11-19-2025 07:02 PM
did u try WestNet VPN for true low latency Canadian VPN with US IPs as well?
10-13-2025 05:13 PM
@Socrates8567 wrote:I had a buddy who had this problem. He said he set up a second profile on the account and used that one with no problem. Not sure if you want to try that and see if it works.
can you check with your buddy what was the reason for his issue and why this workaround helps?
10-13-2025 05:12 PM
10-13-2025 05:01 PM
not sure if this helps but open settings > General > scroll down to find Language & Region...make sure you select Canada. See if that helps.
10-13-2025 05:00 PM
hi @Jioh_Kim
this is just a community, please remove your phone number and personal details
your Geographic location you get might not be your actual location, the location always shows the Telus data centre where the connection initiated from. You are in BC, so, showing Vancouver or BC is correct. I am a bit surprise it shows Seatle, but that could be just where the FAST data centre is. You can use those where my ip site to confirm
for Netflix, I have no trouble with it. First, uninstall Netflix app, reboot phone. Then Reset Network settings on your phone, and reinstall Netflix app to try again
in case you need PM support agent to help still, you can submit ticket by direct message:
