01-03-2020 01:50 PM - edited 01-05-2022 08:51 AM
I have tried different browsers (Chrome and Firefox), have tried clearing cookies, have tried different locations (at work and at home) and I'm still getting this error when I login and try to view details about my current plan:
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page
01-03-2020 02:58 PM
I'm still unable to click on "Plan Details" link from the "Overview" page after I login. I've tried logging out many time. I've tried incognito mode.
01-03-2020 02:55 PM
Which page are you trying to look at?
I too was having the same error when I tried to look at my rewards.
It seemed to happen right after moderator applied a manual adjustment to my account.
At the time, I didn't feel the need to contact moderators again to fix it.
Lo and behold, the problem fixed on its own after my next renewal.
So if it's something you need to see like your overview page, then you should contact moderators to take a look. Otherwise if it's not important, then it will likely repair itself in due time.
To contact moderators, click on the green question mark at bottom right to get started.
Enter your question into SIMon. Follow/invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
01-03-2020 02:20 PM
Seems to be working now..... 👍
01-03-2020 02:13 PM
@olga85m wrote:I have tried different browsers (Chrome and Firefox), have tried clearing cookies, have tried different locations (at work and at home) and I'm still getting this error when I login and try to view details about my current plan:
Oh no!
It looks like something went wrong, but don’t panic.Log out and then log back in again to continue. Or return to the Login Page
Wait a liittle bit. It should fix itself.
01-03-2020 02:09 PM
Oh no!
@olga85mWebsite problem just keep trying every hour and it should eventually be back up and running.
01-03-2020 01:53 PM - edited 01-03-2020 01:54 PM
Maybe wait a bit and try incognito
Sometimes part of the selfserve stall for some time
Yup mine is failing too
Just try later
