01-15-2020 08:16 PM - edited 01-05-2022 09:02 AM
Hi there. I currently have $40 5GB data plan, I want to change it to $25 1GB data plan on the next billing date, but I can not figure out how to change it? I keep going pressing change plan button but nothing comes up (see the attached screenshot). I tried other browsers and even phone browser. Please help, thank you!
01-15-2020 08:51 PM
@Tessabrown0722 , Just try@wetcoaster's solution. If it worked here, it should also work for you.
@wetcoaster wrote:
@arshbuttar wrote:Hi there. I currently have $40 5GB data plan, I want to change it to $25 1GB data plan on the next billing date, but I can not figure out how to change it? I keep going pressing change plan button but nothing comes up (see the attached screenshot). I tried other browsers and even phone browser. Please help, thank you!
Does the change show up under the plan and add-on tab?
If not you might just need to wait an hour or so and then try again with incognito mode (works well in Chrome for most people)...
01-15-2020 08:43 PM
Incognito mode worked perfectly! Thanks a lot for your help
01-15-2020 08:42 PM
Its not allowing me to it's not showing options and if you click on more details you get a hardcore error notice
01-15-2020 08:42 PM
The best solution would be to contact a moderator. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon . Type moderator and follow the prompts to get to one. Ask them to help you to change the plan for the next cycle for you.
@arshbuttar wrote:My current plan does not show up anywhere on the page either
01-15-2020 08:39 PM
Do you mean it's slow, or not allowing you to change plans?
@Tessabrown0722 wrote:It's doing the same thing to me.
01-15-2020 08:38 PM
01-15-2020 08:37 PM
01-15-2020 08:32 PM
dont worry
it just because the website context loading very very slow
didnt show up the full context.
just wait a bit
01-15-2020 08:31 PM
Hi @arshbuttar,
If you need some extra help to change the plan from the next billing cycle, you can log a ticket using SIMon (our virtual assistant) and we can assist you further. 🙂
Regards,
Ciprian
PM Mod Team.
01-15-2020 08:24 PM
Did you select the plan that you wanted to change to from above?
01-15-2020 08:21 PM - edited 01-15-2020 08:25 PM
