01-15-2020 08:41 PM - edited 01-05-2022 09:02 AM
01-15-2020 09:54 PM
Naa got to give you something to do. ![]()
@CannonFodder wrote:
@gblackma wrote:Lol. Ask PM why they called it "My Account". And you quite literally answered your own question.
@gblackma wrote:Log into my account and see if all your data is gone.
Why would you want the OP to log in to YOUR account!? 😉 😄
Maybe you should have used the part in bold in your previous response, and then you wouldn't have some smartazz replying that way..... oh, wait a minute..... 😉
01-15-2020 09:39 PM
01-15-2020 09:35 PM
01-15-2020 09:22 PM
Good one LOL
01-15-2020 09:18 PM
01-15-2020 08:55 PM
Please login to your account to check your status. If you still have monthly data, turn data connection on your phone. You still can connect via WiFi to browse websites, anyways.
01-15-2020 08:49 PM
If everything checks out that was posted before this post. Data on, calls work, self serve account shows you still have data left then check your APN settings they should be as below for MMS and data.
01-15-2020 08:45 PM
Log into my account and see if all your data is gone. If it is, you have 3 options, wait until your plan renews, buy a data add-on, or contact a moderator and ask them to renew you plan immediately.
01-15-2020 08:45 PM
More importantly, is your data turned on? If yes, please provide more info so we can address the issue you are having.
01-15-2020 08:43 PM - edited 01-15-2020 08:44 PM
More details please?
Is this a new sign-up?
Has data ever worked?
Does your self-serve show data available (as a line xxx/1024MB for example)?
What phone? Does it work for talk and (picture) text?
