Unlocked phone from abroad
cowbow_wow
Hello PM Community,
I'm planning to purchase an unlocked galaxy s10 in Korea this spring and wondering if I can use that phone in Canada. My understanding is that any unlocked phone can be used with PM SIM. Thanks for the help in advance!
1 REPLY 1
will13am
@cowbow_wow, try using this site to confirm compatibility.
https://willmyphonework.net/
Alternatively, if you know the frequencies that are supported by the phone, you can compare against the list of Telus frequencies from this wiki.  You don't need all the frequencies to have a good working phone.  Band 5 and 2 for 3G and band 4 for LTE are pretty much essential.
https://en.wikipedia.org/wiki/Telus_Mobility
