Data not working
Arthuray
For some reason, my data has not been working. When I log into my account, I am unable to see my data usage. Could somebody help me out? Thanks!
ECBomb
One of the good things about prepaid service is they don't allow you to go over your data allotment so you won't get a surprise charge.
Maybe consider enabling the data tracking on your iOS/Android device so you know your data usage or log onto PM to check your data usage periodically.
mimmo
If you had data working and you do. Not see the data add-on in you selfserve, it means you have used up all your data.
You can either:
renew your plan early
Buy a $30 1gb add-on
Go without data
You might also think to change to a higher data plan if this happens often
wting
A Community Moderator should be your best bet in figuring out why your data is not working.  You can following the instructions here to reach out to a moderator.  https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
